Need help troubleshooting elec mirrors 95 XJS
so, the next little issue, on my newly aquired Jag, is the electric door mirrors. When the switch is operated, i can hear a relay clicking, but the drivers side mirror will only angle down, no matter which position the switch is put, and the passenger side mirror will do nothing, no matter where the switch is moved to.
I have done a little reading, and this sounds like it may be the seat control module. Is this a fair assumption ?
I saw the TSB about the SCM and the door mirrors, but my vin is later than any in the TSB.
I am concerned that if the problem is similar to the TSB, then I will have to change the door mirrors also.
Anyone got any tips on how to troubleshoot this problem, and how to tell if the door mirrors have capacitors in them ?
The doors do not lock when activating the alarm, or from the drivers side lock, if that has any bearing on the situation.
Thanks in advance
Thanks in advance
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
