need pix of under body cross braces
Received 1,236 Likes
jag suspension systems were never designed for hard acceleration or braking,(definately not for drag racing),rubber mounted sub moves around to much(great for smooth quiet old people).
i have seen at least 2 rear subs actually ripped out of the body mounts, when pushed hard. one was when backing down a driveway, and yanked the E-brake, wheels locked and frame disemboweled from the mounts,of course old and rusty car! still very sobering sight.
pic of my rear brace system, adjustable ends make some preload on the frame for hard acceleration ! notice single piece aluminum driveshaft saves 30lbs less than factory, plus lower moment of rotation inertia!
Where those with the ripping Convertibles or coupes the Convertibles have multiple re-enforcing things already in place and one would thing they would with to these re-enforced areas
oh, are the "HBE rear one" still for sale any where.
looks like some one could weld one up... not me I do not weld...
Jonathan-W (01-12-2015)
It is not tied to the boot like the Jaguar convertible brace. To reduce body flex it would need to be tied to the body at 4 points minimum.
I installed the "HBC" front X cross brace (over $300 with S&H) soon after I got my 91 conv . It had front end shimmy at 55mph pretty bad even after front & rear alignment. That was/is a cure for this type of condition in conv's. In most case's. I understand their a stock idem on later model XJ-S's, don't know. As Ron said, the stock IRS is not meant for "hole shot" type starts, especially with a manual transmission or lower diff gear ratios . You will rip those rubber mounts lose. That goes for OEM or aftermarket mounts. "Be there done that".
