New 1990 XJS owner, headlights don't work, advice?
I just purchased my first Jag. Everything is in pretty good shape. A few minor problems. The most urgent is the headlights don't work at all. The turn signals and brake lights work. I have not checked anything yet. The seller told me they did not work and had not tried to fix them. I am hoping it is just a fuse or something simple. Any advice on where I should start?
YOu are correct to start with the fuse.
Then goto the headlight itself. Test for voltage there. it is UNLIKELY that both would be burnt out, but possible.
Fuse, bulb, switches (both teh turn knob and the dimmer on teh turn signals)
David
David
Well it is not the fuse. There are 4 headlights so I am sure they are not all 4 burnt out at the same time. Is there an inline fuse somewhere? How about a relay? I turn on headlights and hit high beams and still nothing. How do I check the switch? Any help would be appreciatted.
Large silver Hella relay, left component panel under hood. Blue wire is feed from headlight switch, should have power when headlamps are turned on. It will, and now either theblue/red wire (low beams feed) or the blue/white wire (high beams) should be hot, but they are not and so your lights are not on. That's beacause the relay is bad. Jump blue to either feed and the lights will come on.
Message me private if you want a good used one, they are expensive to buy new.
Guest
Posts: n/a
Hi my name is steve I have a 1993 Jag xjs that I think needs a relay for the headlights do you have one low beams don't work?
my e-mail address is sjhammer@live.com
Tony K
03-26-2024 01:53 PM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
SingBlueSilver
08-27-2015 02:20 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
