New brake oil warning
Old 11-28-2015, 07:49 AM
yellowapple's Avatar
Default New brake oil warning
Hello,
My brake oil warning light is on and I suppose that this coming from the tank.
My current solutions is to make a short-circuit at the switch level (A wire between the two cables).
Do you have another idea?
Thx
yA
Old 11-28-2015, 09:31 AM
Wayne'sJaguar's Avatar
The warning light may be on due to 1)low fluid in the master cylinder reservoir, or, 2) a loss in pressure in either the front or back brake system or, 3)a wiring issue. If you put a wire between the 2 wires at the master cylinder cap switch, that will keep the light on, as your switch thinks you are low on fluid, I believe.
Your problem may be with the differential pressure switch (#2 above), if your car is fitted with one; if this is the problem, it will be necessary to reset this switch but more importantly, to find out why there was a lower pressure on the one side (front or back). You may have a leak of brake fluid? Was the master cylinder level down?
Hope this helps!
Old 11-29-2015, 03:41 AM
Hi, thank you for your reply.
I've put a wire between the 2 wires and the light is off. The fluid level is good and seems to be constant.
Thx
Dudeman44
12-17-2015 05:29 PM
amaezing
12-03-2015 09:52 AM
weattg44
12-02-2015 01:06 PM
domino_z
11-27-2015 08:40 PM
talashek
11-26-2015 12:18 AM
Quick Reply: New brake oil warning
