New A/C system, air routing issues
Old 08-09-2014, 06:22 PM
J_C_R's Avatar
Default New A/C system, air routing issues
I've got the "custom designed" A/C system installed, and finally evacuated and charged it today. Produces plenty of cold air...too bad I can't direct it out the dash vents :-(
The system seems to 'leak' air everywhere at once, through the defrost vents and the heater vents. Virtually nothing comes through any of the dash vents.
In the attached photo I've removed the glove box and the access panel to the chamber that contains the heater core (left side of photo tilting forward), and behind that we can see the evaporator. Far right shows the blue intake tubes that suck environmental air in.
What I can't see is how to access or adjust any vents or ducts that direct the flow of air to the floor, the center vents, or the defrost vents. Mine is an '87, and the diagram in Palm doesn't seem to apply.
I do have the "hot cold" slider switch just below the radio, but sliding it one way or the other makes no difference on where the air ends up.
My temperature switch (on the left side of the radio) has the "manual override" feature, which doesn't do anything that I can tell when I pull it out.
Thoughts?
Thanks,
John
1987 XJ-S V12
64,000 miles
Attached Thumbnails New A/C system, air routing issues-vent-system.jpg
Old 08-10-2014, 11:28 AM
Bc xj's Avatar
I had same problem on my car. No air to center vents. It turns out I had a big vacuum leak on firewall. I think the main vents are controlled though servos and the center vent is vacuum operated.
SD96XJ6L
01-12-2022 04:30 AM
Stoney85
06-10-2021 09:14 PM
Stoney85
Australia - Queensland
06-07-2021 11:49 PM
Rupesh
03-25-2016 03:33 PM
johanasu
09-03-2015 12:39 PM
Quick Reply: New A/C system, air routing issues
