New front GAZ shock adjuster stuck
SOLVED. Thanks for all the replies . After a bit of reading it is advised to hit the flat face of the adjuster with a hammer (lightly) as the dial can dislodge from whatever is behind it in transit or general bumping. I generally don't like to just hit things with a hammer to solve things (well I do actually..) but as it turns out it works. In my case I used a shifter as it is flatter and can fit between the spring to get a hit on it and whalaaa it worked. I now have around 14 odd clicks on the adjuster.
petemohr (03-31-2022)
