New Key Fob
Beavis,
If you got the vehicle care handbook when you bought your car that should show you the style of remote fob you need - the cases were pretty fragile & it's possible a previous owner swapped the correct working circuit board into the wrong case.
Model Year is largely irrelevant here in the UK - we're more into year of registration but if your car is a mid to late 1992 registered car it would be classed in the USA as a 93MY car. Are the last 6 digits of your VIN higher than 179737? If so I'm confident that the part you need is this:
Rgds.
A.
Rgds.
A.
Date: Tue, 10 May 2016 08:25:09 +0100
Subject: Re: Jaguar Heritage Parts Enquiry -
To:
Hi Richard,
The DAC7990 transmitter was part of a retrofit alarm system - Part No.JLM1768, which was fitted after the vehicle left the factory.
Also you must press a remote after every beep to set it up to work. Even if you only have 1 you must press the same one 5 times.
I have the instruction manual and installation booklet for that alarm system.
Where did you get the fob from. I can only find the 433 MHZ ones not the 418 for the "92 MY. How much ?
See attached PDF document one is 433Mhz other is 418Mhz
Options that a modern alarm can bring, that's all.. something to think about ;-)
Padre
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/800x532/sdsc_8720_9d891003e5d0f944f281d4396672eb8bd5424aa3.jpg)
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/800x532/sdsc_8721_a5584ed2851126b11e06f4d5129d80932cafc258.jpg)
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/800x600/sdsc_8722_4ef321cfb0be0c5df981ecc4edca9f92458482d4.jpg)
Capatain Indignant,
To avoid disrupting Beavis's thread, you may find this thread of interest:
https://www.jaguarforums.com/forum/x...roject-159355/
Paul
Paul
#30
PC210
05-14-2016 11:29 AM
