New Key Fob
Old 05-10-2016, 03:18 PM
Beavis's Avatar
Originally Posted by bigpigpants
Beavis,
If you got the vehicle care handbook when you bought your car that should show you the style of remote fob you need - the cases were pretty fragile & it's possible a previous owner swapped the correct working circuit board into the wrong case.
Model Year is largely irrelevant here in the UK - we're more into year of registration but if your car is a mid to late 1992 registered car it would be classed in the USA as a 93MY car. Are the last 6 digits of your VIN higher than 179737? If so I'm confident that the part you need is this:
Rgds.
A.
After some e-mails back and forth to Jaguar Heritage, I now have the answer. It seems that its the correct fob for the Jaguar aftermarket alarm kit that I have fitted. Which is good news, as it should mean I can take it out easily!! Anyone have the fitting instructions for the kit?
Date: Tue, 10 May 2016 08:25:09 +0100
Subject: Re: Jaguar Heritage Parts Enquiry -
To:
Hi Richard,
The DAC7990 transmitter was part of a retrofit alarm system - Part No.JLM1768, which was fitted after the vehicle left the factory.
Old 05-10-2016, 04:10 PM
Paul_59's Avatar
Banned
Originally Posted by malc4d
Also you must press a remote after every beep to set it up to work. Even if you only have 1 you must press the same one 5 times.
I have the instruction manual and installation booklet for that alarm system.
Where did you get the fob from. I can only find the 433 MHZ ones not the 418 for the "92 MY. How much ?
As you discovered the circuit board is identical to change the frequency if you are handy with soldering iron you can change component that generates the frequency it's a saw (surface acoustic wave oscillator)
See attached PDF document one is 433Mhz other is 418Mhz
File Type: pdf
File Type: pdf
Old 05-10-2016, 06:06 PM
malc4d's Avatar
Didn't you get my emails with the instruction and fitting leaflet .?? Sent to you two days ago Richard.
Why would you want to take it out. I just love the remote locking doors.
Beavis (05-11-2016)
Old 05-11-2016, 01:18 PM
Beavis's Avatar
Got them thanks - were hidden in Junk mail..
Options that a modern alarm can bring, that's all.. something to think about ;-)
Old 05-11-2016, 08:18 PM
malc4d's Avatar
Still l think a few of us would like to know.......... did it beep and pair up at least ??
Old 05-12-2016, 01:51 AM
Beavis's Avatar
Still l think a few of us would like to know.......... did the beep and pair up at least ??
Will let you know when I have the car back, still at the garage being fettled ;-)
Old 05-12-2016, 11:08 AM
CaptainIndignant's Avatar
Related question - is there any way to replace the battery for the flashlight in the pre-transponder keys? I can't seem to find an illustration anywhere and just pushing on it doesn't suggest a clean way to disassemble the head.
  #28
Old 05-12-2016, 11:24 AM
Padre's Avatar
On the side opposite the button, there should be a little rectangle with the words Jaguar. Push that in and pull the unit apart.
Padre
Old 05-12-2016, 12:51 PM
ptjs1's Avatar
Received 3,033 Likes on 2,015 Posts
Capatain Indignant,
To avoid disrupting Beavis's thread, you may find this thread of interest:
https://www.jaguarforums.com/forum/x...roject-159355/
Paul
  #30
Old 05-17-2016, 06:41 AM
malc4d's Avatar
Any news.....waiting with baited breath here !!
xjsman89
09-21-2016 09:55 AM
PC210
05-14-2016 11:29 AM
PhilM
05-13-2016 01:12 PM
Salu498
05-02-2016 10:30 PM
Maraud
04-30-2016 08:49 AM
Quick Reply: New Key Fob
