New member
Hello, just purchase a 1995 XJS 2+2 4.0 Liter. Had lots of problems some minor which I've been able to correct. When I purchased to car the roof worked fine all of a sudden wont go up or down. Checked fuse to day, the 30 amp in the motor is good.. Have to admit I'm not very good at electrical issues.
Second think not so minor, I have no front parking lights. When I move the headlight switch to the middle position I get side markers, tail lights and the headlights flicker. In the full headlight on position I have headlight, including high beams, tail lights, brake light and turn lights. Tail lights are very low, probably will replace with leds.
Any ideas will be appreciated.
Captain Bob 369 (09-16-2021)
Welcome to the circus that is Jag ownership. Don't stress over the Jag it is just letting you know who the boss is, don't ever ever say my Jag is perfect because it will hear you and make you pay.
There's always something going on, especially electrical as you've clearly figured out.
Dim bulbs are a sign of either dirty contacts or bad earth connections, can't really help with the locations. I've no experience with the powered hood at all but the switches used by Jaguar weren't exactly the best, that goes to for the light switch and column switches too which can be a real pig if not used regularly. May want to start working you way through methodically cleaning up connections, disconnect, clean, reconnect - many cleaning agents possible - some use lemon juice, I use dedicated contact cleaner, personal choice really.
Bob, welcome to home of the phrase "misery loves company", lol.
This forum is the absolute best resource available. Use it whenever needed, but try coming back regularly when you don't as well. I have found threads for things I did not know, had.t thought of or simply found interesting and/or entertaining.
Tail light brightness is an issue in XJS's due to the facelift changes, making the lens darker. LED's are great, but try swapping old for the new "brighter" regular type. I found a noticeable difference without issues of fit or voltage draw. Of course, canned air or a compressor with a thin air nozzle is great for just blowing out years of dust/dirt/grime to begin with while changing the bulbs.
Dave in AZ
Dave in AZ
