New Member needs assistance
Hi all, my 1980 Pre HE 5.3 V12 Jaguar XJS Auto has just gone through a nut and bolt restoration, I need help and guidance with a Speedo related issue, It has stopped working, I have removed the clocks and the insturment cluster is fine, I have checked the cable drive from the gearbox and the cable is fine, leaving me with the concern that the speedo drive located in the end of the gearbox is now broken, how can I check out this element please, and if it is due to the drive failure, how do I remove the broken one, will I loose the Auto fluid etc, and where do I get a replacement from, and what specifically am I asking for,
I look fowards to any help you can offer,
Sayers
Sayers
Grant Francis (09-21-2020)
Sayers
Sayers
The following 2 users liked this post by Greg in France:
Grant Francis (09-21-2020),
Mac Allan (09-21-2020)
Greg in France (09-21-2020)
Ensure you count the teeth on the old one carefully, you must have the same number. The parts are colour coded, so if you remove a (say) brown one, in theory a new brown one will have the same number of teeth.
MK2
11-27-2016 02:15 PM
