new rad different fittings what to do
identicle rad came in but with diff fittings, mine had screw on type pressure looking fittings for trans fluid, this one has low pressure slip on tubes coming out. what to do??? 2 of them on the passenger side u.s. one under rad hose and one on bottom above other rad hose....
Good advice about an extra trans cooler though!
Greg
Qgregg (05-05-2012)
Qgregg (05-05-2012)
There is line pressure at those fitting. No problem with hose clamps. We use them on the fuel system and if dead headed the pressure goes quite high with no problems. Some manufacturers use hose clamps on A/C lines.
Early cars had a hose with clamp connection, later cars have flare fittings.
aholbro1
08-05-2021 05:02 AM
xjrjag
09-27-2015 01:53 AM
Dickie_L_J_O
09-13-2015 07:44 AM
