New shocks and springs for my XJS
I ordered the Sport Spring Set from the Driven Man.com for my 1995 XJS 4.0. I installed the front springs and my new Bilstein shocks over the last couple of days. I used the threaded rod method to remove the first spring, after 2 hours of wrenching, the first spring was out. I figured I would try a floor jack to assist with the install, I kept the threaded rods in place, jacked the spring up about 1/2 way, threaded the nuts up to the bottom of the pan then jacked up the rest of the way and secured the spring pan in place, this took less than 1/2 the time as the removal. I also replaced the shock. Thanks to AllanG for giving me the torque spec for the eye bolt nut.
The new springs dropped the ride height from 15 1/2 to 14 1/2 inches. The ride quality also increased.
The one thing I did notice, is that I now get a squeak from the suspension. I removed the shock and tested, still had the squeak. Don't know what to do about the squeak, any thoughts.
I will do the rear shocks and springs in the near future and will report on that when done.
Keep it on the road.
Took the car for shakedown drive, she I got back looked like the suspension squeak is gone.OTE=EJ Garity;937168]I ordered the Sport Spring Set from the Driven Man.com for my 1995 XJS 4.0. I installed the front springs and my new Bilstein shocks over the last couple of days. I used the threaded rod method to remove the first spring, after 2 hours of wrenching, the first spring was out. I figured I would try a floor jack to assist with the install, I kept the threaded rods in place, jacked the spring up about 1/2 way, threaded the nuts up to the bottom of the pan then jacked up the rest of the way and secured the spring pan in place, this took less than 1/2 the time as the removal. I also replaced the shock. Thanks to AllanG for giving me the torque spec for the eye bolt nut.
Keep it on the road.[/QUOTE]
Received 10,906 Likes
I also have a 95 XJS 4.0, and had looked into the Driven Man system but I kept hearing that it lowered the v12 car and not the 4.0 car. SO I removed the two shims on each front side and got about 3/4 inch out of it. I really wanted to get all new shocks/springs as well as improve the stance but everyone seemed unsure of the best way on the facelift cars. I attached a pic of my car currently. Please fill me in as you complete the install and the details of exactly what you purchased!! Thanks!
Flint Ironstag (03-26-2014)
Like I mentioned earlier, after I did the front it lowered about an inch. I was having a tough time finding a place to put the springs on my new shocks so I bit the bullet and spent 35 bucks on one from O'Reillys, I tried it on one last night, worked good. I'ok just keep plugging along.
UOTE=ajyiii;938256]I also have a 95 XJS 4.0, and had looked into the Driven Man system but I kept hearing that it lowered the v12 car and not the 4.0 car. SO I removed the two shims on each front side and got about 3/4 inch out of it. I really wanted to get all new shocks/springs as well as improve the stance but everyone seemed unsure of the best way on the facelift cars. I attached a pic of my car currently. Please fill me in as you complete the install and the details of exactly what you purchased!! Thanks![/QUOTE]
Possibly your Squeak could be coming from your control arm rubbers, because you have lowered your car they are rubbing/sitting at a different point and probably not worn in there? Have you changed them, or are they still original? If original I would recommended changing them. Note: It's an utter Bastered of a Job but uppers are easier but the lowers forget it, I did it off Jack Stands never again thats why I bought a hoist!
Good Luck
Good Luck
Guy-Pierre Boucher
09-16-2015 05:55 PM
Tar
09-06-2015 11:24 AM
