New V12 Squeaking Sound
Its a beautiful day, so when I got home from work I thought I'd go for a short spin in the XJ-S. I started it up and there was a squeaking sound that it hasn't made before. It doesn't sound great, so I took a short video and turned the car off. I'm suspecting the AC compressor. It seemed to be in that area, but it could be any of the other belt driven accessories as well. Anyone able to pinpoint it for me? Its an '87 if it makes a difference.
If you're not sure what I'm on about, compare to the same engine recorded in September.
Fan belt squeak.
Mine do that when unused for a while, sound like Crickets at mating time.
Let them warm up, the belts, not the crickets, and once the rubber softens they usually shut up.
Moral, use it more.
If it stays squeaky, the belt is past its use by and replacement is needed.
You are right, the A/C is the culprit on all mine.
Sometimes a SMALL tighten of the belt sorts that noise, sometimes not.
Moral, use it more.
Greg in France (05-26-2021),
orangeblossom (05-26-2021)
Grant Francis (05-26-2021)
