New XJS owner
Old 11-18-2016, 06:59 PM
Johnde's Avatar
Originally Posted by daverb
Dido on that. that why after the second year of ownership, I put mine up and did all Greg mentioned plus rebuilt my injector harness and placed it of the valley
Well, i overtightened the nut when attaching the battery wire to the pump, broke the screw off ........ walked away for a day, now ... getting ready to solder the wire to the pump..... any opinions before i do that , or... how risky is that ?
Old 11-19-2016, 03:47 AM
orangeblossom's Avatar
Received 3,812 Likes on 2,639 Posts
Have you ever had any Petrol flowing through it?
Old 11-19-2016, 06:08 AM
Johnde's Avatar
No, no gas has run through the new pump, old one still attached, so itll be ok to solder the wiring before i put it in line ?
Old 11-19-2016, 06:15 AM
Greg in France's Avatar
Received 9,331 Likes on 5,475 Posts
Yes, but do it as quickly as you can. Do not get it too hot so you fry some component inside. I suggest you solder on a piece of wire and put a connector onto that piece. test it, then coat the soldered part in a support coating of epoxy glue: Araldite, JB weld etc. So it does not vibrate loose at the most inconvenient moment. The tape the piece of wire to the pump body firmly, so the wire is not putting vibrating stress on the soldered part.
Greg
The following 2 users liked this post by Greg in France:
Grant Francis (11-19-2016), orangeblossom (11-19-2016)
Old 11-22-2016, 11:00 PM
Johnde's Avatar
Pump in, car started, smelled a burning odor, after a few seconds, shut it down, saw some smoke from the engine compartment. Kinda smelled like wire burning, but not sure, did not see any evidence of that. Then noticed some gas dripping from the pump, did not have time today, but will pull and reattach the pump Saturday, then restart the car, probably keep a fire extinguisher handy , car hadnt been started in at least ten months, maybe more, any ideas on what it could be smoking from the engine dept
Old 11-22-2016, 11:50 PM
Hi Johnde
Gas/Petrol dripping from the Pump could be a loose or distorted Jubilee Hose Clip or maybe some sort of back pressure, in the event of an outside chance that the New Fuel Filter may have been put on the wrong way round, or blocked if you're using the old one.
As for the Smell of Burning Rubber it could be from a belt, if something like the Alternator - Aircon Motor or Water Pump has seized up.
The following 2 users liked this post by orangeblossom:
Greg in France (11-23-2016), Johnde (11-25-2016)
Old 11-26-2016, 12:27 PM
Johnde's Avatar
Ok , so reattached the pump, started car, idled for 5 minutes , ran up and down my street, circled a few parking lots, some light gray smoke was coming from the engine along the engine fire wall/ driving compartment. Car stalled once, restarted right away, parked it home hsppy that I was up and running, went to drag wife along for a ride( in the illegally unregisteted car lol ) andcwould not start. Seems like battery drained. So was the smoke the alternator belt ? Kinda had an oil smell, saw some cheap alternators at rockauto.com,any more advise ? I know im in for a nice long term project, the engine roared and felt good accelerating.
  #28
Old 11-26-2016, 12:45 PM
Hi Johnde
Before you buy a New Alternator, you really need to find the cause of the problem, as it could have been something else like a seized pulley.
Old 11-27-2016, 02:34 PM
Johnde's Avatar
Jumped car, started right up, drove nice, must be the alternator i guess ? No smoje coming from engine today , car ran smooth.
Notice the wiring strewn across the engine, is this safe ? Is this how it was designed to be ? How do i fix that ? Any ideas ?
  #30
Old 11-27-2016, 02:35 PM
Johnde's Avatar
Also the green wire near the radiator/oil cap is disconnected, any idea what it is for ?
  #31
Old 11-27-2016, 02:56 PM
usaf's Avatar
Does anyone know how to post on here, I'm new today and can'find where to make a new post..thanks for any help, im trying to find out what P0152 High Voltage Bank 2 Sensor 1 is and how to correct it. Desperate in Missouri.
  #32
Old 11-30-2016, 08:19 PM
Johnde's Avatar
  #33
Old 11-30-2016, 11:05 PM
baxtor's Avatar
Received 1,165 Likes on 754 Posts
Not sure what you mean by radiator/oil cap John.
Need a closer pic to be able to identify individual wires and an idea of the termination points.
  #34
Old 12-13-2016, 12:45 PM
Johnde's Avatar
Default Xjs alternator
ok , need to replace my alternator in my 1985 xjs, i picked up a 115 amp to replace the 75 amp as ive read that the extra amps will improve the timing of the engine. Is that true ? Also any advice on replacing the alt. ? I have to reuse the pulley, do have a new belt, does not look to be all that hard of a job, anyone here have any much needed advice ? Thanks
  #35
Old 12-13-2016, 06:08 PM
warrjon's Avatar
Received 2,576 Likes on 1,712 Posts
It's not too difficult to replace the alternator. It has a separate belt BUT it's at the back so you need to pull the other belts off to replace the belt.
Mine went in from the top so you'll need to
remove the RH air filter assembly.
remove the AC belt tensioner.
disconnect wire's from alternator.
remove bolts for alternator bracket from block most are accessed from underneath I think 1 or 2 I got from the top, but you'll work that out.
remove alternator from top.
A 115 amp alternator will do nothing for the timing of the engine. It will allow you to run more electrical equipment, electric fans etc.
orangeblossom (12-14-2016)
Jaguar2986
01-02-2017 06:25 PM
JLBolen
11-24-2016 01:50 AM
chopperdave
11-15-2016 10:39 PM
neuroticartist
11-10-2016 07:36 PM
Sylvain
10-15-2016 04:44 PM
Quick Reply: New XJS owner
