New XJS Owner!! Fuel Hose question
Finally found the XJS of my dreams, brought her home last night. She's an '83 V12 Coupe. She seems pretty well sorted, I bought the car from a Jaguar and Rolls Royce collector who's replaced a lot of parts. The leather is a little worn and it will need a respray, but it's completely rust free believe it or not, with just over 100,000 miles. I put 100 more on driving it home and enjoyed every second. It even has a "JG 200" Radar detector made specifically for the XJS and installed by the dealer that still works.
I'd really like to replace the fuel hoses on her ASAP, the PO says they were inspected when he had the fuel pump replaced last year, but I'd rather err on the safe side. My question is, Would it be advantageous to just but EFI fuel hosing and cut/fit them myself? or should I buy V12Performance's kit? Is there any other hardware I'm going to need if I just go the bulk EFI hose route? Any other tips on this particular job?
Is there a source for a new shifter ID plate? Mine is cracked around the cruise control switch and it's gonna drive me insane, but I can't seem to find a replacement anywhere.
I'd also like all of your input on what else I can do to as far as preventative maintenance goes? The fluids were recently changed, and it was tuned up. I've ordered contact cleaner to get started on that project and I'm planning on doing an LED upgrade. Am I missing anything? Advice? Thanks so much.
Best Regards,
Brendan
Best Regards,
Brendan
Contact S.D. over at Jaguar Injector Service;
Jaguar Fuel Injector Service
He has all of the parts you need and pre-cut hoses. S.D. is very knowledgeable and he ships quickly.
I have purchased several kits from him and have been very satisfied.
Mark
Mark
The following 2 users liked this post by Safari:
Dymaxxion (07-12-2015),
someguywithajag (08-19-2018)
Received 10,979 Likes
Good idea to replace the hoses, yes, and agree with Safari's recommendation of Jaguar Fuel Injector Service. Top notch service.
Beside the actual injector hoses you also have the 4 supply/return pipes....which have rubber sections. The rubber sections can be cut off, however, and new hose pressed on. Easy. Dave (SD Faircloth) can fix you up.
Or.....
Buy the fuel injection hose locally and do the job yourself. You'll need to buy the hose 'ferrules' from SD or some other supplier, though.
Or.....
Is not so much a matter of dirt. It's a matter of the hoses becoming dry and brittle......and then cracking. Worth worrying about !
The hoses are EFI 5/16, I did my own and reused the old furrels. the way I got mine off was to cut the as close as possible to the fuel injector and rail, then used a soldering iron to "slice" down into the furrels. may be a bit time consuming and smelly but works. as for the furrels, I I heated them up a bit and used an exato knife to scrap any residue left ( used vise grips or plyer to hold while heating with propane tank or son other heating source) Then used a wire brush installed in drill to clean and buff the outside
Great looking car, I have a 84
I replaced all my fuel hoses last year when I replaced nearly everything else on the motor, from memory it took nearly 3m of hose. I did a lot of research and I ended up using Gates Barricade hose, http://www.google.com.au/url?sa=t&rc...97653015,d.dGY
I have seen what these modern fuels do to fuel lines and as I’m a biodieselist if such a word, I know the effect that certain additives that are present in fuel that can destroy or weep through lines.
Don't have a picture of it yet but did paint mine, I used a gold Hi-Temp paint with ceramice in it
