No Blower from Fan switch
Does anyone have the electrical schematic for a 1988 XJS-C,specifically the part for the wiring to the blower switch and blower motors? I'm trying to find out if either the fan switch that controls the heat/ air conditioning is bad or if I've got two bad blower motors. Can the blower motors themselves be tested by hooking up 12 volts to each blower connection plug or is there another way to test it? Is there a way to test the fan switch as I do not want to go thru the tedious process of removing the blower motors knowing that it's just a bad fan switch? Can someone please help? Are there fuses or relays that may be causing this problem and where are they located?
This drawing may help. http://www.jagrepair.com/images/Elec...Electrical.pdf
12v on the fans will, at least, rule them out.
Received 10,872 Likes
https://www.jaguarforums.com/forum/x...-manual-83961/
Go to post #19 in this thread where you'll find a link to the Delanair MkIII training manual. It should help
I have to drive from Toronto to Montreal tomorrow: about 600km. Today I turned on the A/C and nothing happened. No blowers, no vents, no nothing.
Five minutes of searching and I found your post. Add two minutes to read the first few pages of the manual, five minutes more to find my spare fuses, and two minutes more to change the first fuse mentioned in the manual.
All fixed now. Thank you so much. 🥶
Greg in France (05-20-2024)
A Dopo
02-07-2013 09:08 AM
