no brake fluid to LF caliper
so three out of my 4 wheels stop right now, firm pedal, instant stop. the LF cailper gets no fluid at all. I disconnected the line at going to the LF from just under the master cylinder. I can start the car and pump, pump with key on (and hear what sounds like the ABS pump) and engine off, or pump away with engine and key off. I get no brakes to the LF. I have verified the caliper is working. What am I missing?
Each wheel has it's own individual line coming from the actuator/master cyl unit. So you have a problem with the main unit. My guess is that pads have been changed without clamping the hose and opening the blled screw. That leads to possibly contaminated fluid being pushed back into the ABS unit which is extreemely sensitive to dirt.
As a starter I would try to flush the system with a fair amount of fresh fluid. If that doesn't help look up the otehr two threads just running on the system giving info on repair, parts, overhaul help etc.
I did disconnect the LF line from the module. Nothing comes out at that port, not even a dribble. I found a TSB on tearing down the module with a repair kit. I was hoping there is a way to test the acuator before hand. Tried the search w/o luck before starting a new thread. I am no forum guru, I'll try that again :-)
http://rennsportkc.com/jaguar-xjs-ate-abs-repair/
I should have just attatched the link to the end of this thread! My bad.
Dimitrigregorio
17
09-05-2019 03:47 AM
wvanepps
10-04-2015 10:01 AM
Richard_gib
09-12-2015 07:08 PM
