no break lights
Hi flatbroke
You are on the right forum, this is the XJS Forum
If your Brake Lights are not working and assuming that they were working before, there are only about 4 Reasons why they are not working now
(1) Both Brake Light Bulbs have blown both at the same time (very unlikely but stranger things have happened)
(2) The Brake Light Switch has Broken (possible but probably not)
(3) A Fuse has Blown (highly likely) (open the Fuse box panel under the Passenger knee pad with a Coin) and Check the Fuse
(4) Replace the Fuse and see if the Fuse Blows again
(5) If it doesn't blow then you are good to go
(6) If the Fuse does Blow again, then it is Highly Likely, as in 95% Likely that you have got a Trapped Wire that is causing the Fuse to Blow when you depress the Brake Pedal
While it could be a Faulty Switch, its much more likely to be a Trapped Wire shorting out
This is the Foot Brake Switch, check for a Trapped Wire under the Footwell
I have an 87 XJ6 with the same problem - the brake lights do not come on. I have taken the switch out DAC1308 - the arm articulates fine. What else could cause this not to work? For a while the brake lights would work, didn't work, etc. Anything else I should look for before purchasing a new one...
Also, which fuse to look at ?
Juliesjag69
09-25-2014 05:38 PM
