no fuel
no fuel
vehicle is 1994 xjs 2+2 4.0 engine. The car abruptly quit running and an obvious no fuel problem. Fuel pump fuse is good and bought a new fuel pump relay. I have power on one spade of the fuel pump relay plug, but the power goes no further than that. Double checked and reset the inercia switch and put new relay in the ems control in the passenger side footwell A post. Removed the fuel pump and the fuel pump motor works when direct power is applied. So I think there is something not allowing the fuel pump relay plug to engage. What can I check next.
Miami John
Miami John
John,
I wouldn't change any more parts yet as you're not really verifying where the original problem lies.
I would just follow through the wiring diagram in the logical order of Ign switch to Main Relay to ECU to Fuel Pump Relay to Pump to determine which one is preventing the pump from running.
When you say you "reset" the inertia switch, do you mean that it had tripped? Naturally, you could just bypass that if it shows to be faulty.
Good luck
Paul
Good luck
Paul
Grant Francis (05-20-2023)
Greg in France (05-20-2023)
Update: problem resolved! The cause of the no fuel was a bad fuel pump relay. I had bench tested the original relay, which clicked open and closed just fine, but the resistance was questionable. I did not know what the resistance should be, but I never got a consistant reading. So I installed the new relay cleaned all connectors and it fired up So even though a relay may click open and closed, testing it further is advised.
Miami John
Miami John
The following 6 users liked this post by miamijohn:
David84XJ6 (05-20-2023),
Greg in France (05-21-2023),
JJS- Florida (05-22-2023),
ptjs1 (05-20-2023),
RickE (05-21-2023),
and 1 others liked this post.
