no impulse at injectors
orangeblossom (05-04-2018)
there is no need to go to jaguar for the cable. economically, it is not in Jaguars interest to be UP on these cars. they are 25 and 30yo... we are not where their money comes from. I knew when i accepted this car, i was kinda on my own - which was kinda cool and,,, thank god for the forum. I wouldnt have ventured here without rhe forym...
in this tech age there are many many sources for this cable. I bought some (a lenght) for dirt cheap a while back. I think warrjon, Doug, Grant or GiF walked me thru my needs waaaaay back at the beginning of what I am learning is my short journey, so far. I have a long way to go.....in more ways than one - ohhhh this life, lol.
The following 3 users liked this post by JayJagJay:
there is no need to go to jaguar for the cable. economically, it is not in Jaguars interest to be UP on these cars. they are 25 and 30yo... we are not where their money comes from. I knew when i accepted this car, i was kinda on my own - which was kinda cool and,,, thank god for the forum. I wouldnt have ventured here without the forum...
in this tech age there are many many sources for this cable. I bought some (a lenght) for dirt cheap a while back. Nothing so special. Ebay. I think warrjon, Doug, Grant or GiF walked me thru my needs waaaaay back at the beginning of what I am learning is my short journey, so far. I have a long way to go.....in more ways than one - ohhhh this life, lol.
knares (05-04-2018)
Some things can be bought aftermarket, some things properly cant.
the fire damaged the oil light switch, so I needed to buy a new one.
I googled the oil light switch and came across a forum, I cant remember where, where they were discussing oil pressure on a XJS 12V
One person said his oil pressure was up to 7 to 8 bar
Another guy said his idled at 5 bar
Generally speaking, oil pressure switches are only good for about 60lb max, so I am told So I had to go to jags
Even 5 bar seems a heck of a lot to me
Unfortunately they all come preassembled and attached to a very rusty XJS body.
The following 3 users liked this post by JigJag:
Also increased pressure can mean reduced volume - like putting your finger over the end of the garden hose - increased pressure but less volume.
#28
O B
drained the tank to day, got about 80lts out of it. followed your instructions but where is the filter
"Once the Tank is empty you can then 'drift' the locking ring off the Sump Tank with a Rubber Hammer and a Piece of Wood (so you don't get any Sparks!)
Clean it out and then Replace the Internal Filter "
thanks
thanks
knares (05-13-2018)
#31
Grant Francis (05-12-2018)
#32
I did away with it on one of mine, rotted out, and then mounted the fuel pump in there, and the 1/2" hose from the main tank ran direct to the pump inlet, and the HI pressure outlet faced the brass elbow in the floor, so about 6" EFI hose, all done.
Many hose joints reduced, and less clutter.
All the other holes were simply plugged with whatever I had in the stash, and sealed with JB Weld.
Tank breathing, drilled a SMALL hole in the cap, job done.
Only draw back is the tank should be kept above 1/4, or maybe, just maybe, there could be a starvation when cornering HARD, or drifting the beast.
Never worried me, coz I dont drive like that.
knares (05-13-2018)
#33
i did say in a earlier post that the guy across the road said the fuel smelt off (he is a very good mechanic and often helps me and my family with these modern car problems)
i dont have much sense of smell but as i drained the fuel today, i started to feel crook from the smell, this has never happened before so he must have been right
#34
O B
thanks
thanks
As soon as you take the locking ring off and then remove the plate, I thought you would see it but in any event you got there so well done
Grants drawing will show the internals in more detail
The following 2 users liked this post by orangeblossom:
Grant Francis (05-12-2018),
knares (05-13-2018)
#35
Depends on the owner.
As usual, deep bow and thanks
#36
JayJagJay (05-13-2018)
#37
Hmm. Do you worry about heat? It seems like it could build up pretty good in the canister as opposed to the thin walls of the rail, metal piping and rubber tubing. I like it though! I do.
what about particulates going directly into the pump, with out the Sump screen? 2 filters, maybe? Just thinking out loud. I mean, the inside of my tank, and others I've seen over the years aren't always a pretty sight.
#38
Aussie mate, no fuel rust down here, near on no Ethanol to worry about, and we DRIVE our cars, the fuel never gets time to go off.
A 1/2" universal filter in the supply hose would do no harm, I never bothered.
Heat, NAH, not an issue, fuel passes too quick to get hot, and the PreHE Sedan had the fuel filter mounted on top of the RH inlet manifold, and they had no issues at all.
Maybe I worry less than most, its a car, drive it, enjoy it, drink heaps, SMILE the SMILE.
JayJagJay (05-13-2018),
orangeblossom (05-13-2018)
#40
Greg
