No Injector pulse no spark 1990
Hello all,
So I pulled the car into the garage 2 days ago to do fuel lines and a water pump, was running great. Finished everything up and went to start, nothing. No spark, (pulled a plug) No injectors- (Noid lighted them, no pulses.) I hear fuel pump kick in as it should, everything else checks out. 1990 V12, Marelli.
All the wires look to be in good shape. I haven't gotten to dash yet so I can't tell you if I have tach bounce because it didn't work before. I have to be missing something. Any immediate things that come to mind?
Thanks in advance.
Thanks in advance.
Received 10,988 Likes
I reckon there could be several possibilities, but....
No spark and no injectors often means you lost signal from the crankshaft position sensors.....or they've failed.
Make sure they're both connected and the pick-up magnets are clean. If that checks out, I'd replace both of them. They each serve I different function (I can't remember which does what) but lot of guys replace 'em both at once and forget about for another 20 years.
Others will chime in with other ideas
The engine will run (POORLY) if the rear crank speed sensor fails but the engine will NOT run if the front position sensor fails.
They are the same part number so I would replace BOTH if that is the problem.
I found this out about 25 or more years ago when I worked at a Jag repair shop.
The engine ran but very poorly, To diagnose I swapped the sensors front to back and the engine did NOT run at all.
I replace the front sensor and the engine ran perfectly.
The original rear sensor failed and when I moved it to the front. the engine would NOT start.
Doug (03-26-2021)
The following 3 users liked this post by WWW:
twocross
08-04-2014 10:54 PM
jag time
04-07-2011 08:14 PM
