No interior lights
Hi,
I am in the process of moving and packed all my Jaguar books.
My interior lights are not working. I checked all the fuses in two locations---under the hood and under the location where the glove box should be.
Are there other fuse boxes in this car? If yes, then where? Any other things I should check for to get my lights working again?
Thank you,
Jomo
Thank you,
Jomo
Don't want to be the one that states the obvious, but have you checked that the light comes on when you toggle it to the rear position (always ON). I had the same issue once, so I pulled and cleaned the door switches, only to find out I had knocked the light into the centre position (always OFF).
Drivers side kick panel, behind there is a black wire with a red stripe, that's the power for the interior lights. I only know this because someone hacked through mine and I found it working on another project. Not saying it's not something else, but that's the power feed.
Yes, always hot. I have a feeling it is actually purple with a stripe. I would start by making sure you have power at the lights. The under-dash units just prise out, as does the central one in the roof.
Do any of them come on with the dash board switches? Does the central roof light come on when rotated to the "on" position?
Also, even if not coming on, open a door and see if any of them have power and report back.
nsl1
06-30-2011 12:29 PM
