no power
fuel system cleaned out injectors removered and cleaned injector cleaner put in the new fuel new plugs,distributor remover and checked all ok leads all ok,starts up first turn of the key with no pedel used ticks over fine just lazy until it gets to 3000 rpm then its revs up fine,but put it in gear its just flat
The A bank temperature difference is probably not related. I'd confirm all your injectors are actually activating. You can pull the whole rail up and support it connect onae at a time. Twist the throttles open quickly and confirm the connected injector fires. Slide a clear hose over the nozzle into a catch can.
Fire potential is high so extinguisher and a helper would be wise.
Greg
Does it have Marelli ignition, or Lucas? Because this sounds like classic "Marelli meltdown" failure, where one bank of ignition fails.
Digital Will
03-06-2020 03:50 PM
bjzwissler
11-07-2016 09:24 PM
Jeff DeVere
10-13-2016 07:00 AM
