No start condition
#41
I got the sensor today (6 days earlier than expected and two days after ordering it) and literally had it installed in 3 minutes(30 seconds to bolt it down, 2 minutes to get the plugs connected (and I have very small hands) and another 30 seconds to pin the plug to its mount)
The car is driving well. Unfortunately the cel is on and I guess it is because of a (previous) bad cps sensor!
So my read on this is the late production date '95 XJS' are OB2 compliant since the '96 XJS started production in I think around May or June of 1995. So if you have a lower priced scanner and it does not communicate with your '95 it may be for this reason and you will want to hook up a more expensive scanner and hopefully it will be able to communicate with your car and allow you to cancel the CEL.
#42
If the CEL came on due to the bad CPS a good scanner will allow you to cancel the code. I will clarify what I mean by a good scanner. Since I have two 95's I found out something interesting. One '95 has a early production date for a '95 which is 6/94 and one has a late production date 5/95. My $100.00 Harbor Freight scanner will communicate with the late production date XJS but not with the early one. My friend has a more expensive scanner and it will communicate with the early production date XJS.
zachster
09-20-2011 11:46 AM
tcbjaguarxjr
11-15-2009 02:01 PM
tcbjaguarxjr
07-29-2009 09:24 PM
Margo
05-14-2009 11:38 AM
