No start condition
Old 05-04-2019 | 04:42 PM
LuvmyXJS''s Avatar
Originally Posted by jomo
I got the sensor today (6 days earlier than expected and two days after ordering it) and literally had it installed in 3 minutes(30 seconds to bolt it down, 2 minutes to get the plugs connected (and I have very small hands) and another 30 seconds to pin the plug to its mount)
The car is driving well. Unfortunately the cel is on and I guess it is because of a (previous) bad cps sensor!
If the CEL came on due to the bad CPS a good scanner will allow you to cancel the code. I will clarify what I mean by a good scanner. Since I have two 95's I found out something interesting. One '95 has a early production date for a '95 which is 6/94 and one has a late production date 5/95. My $100.00 Harbor Freight scanner will communicate with the late production date XJS but not with the early one. My friend has a more expensive scanner and it will communicate with the early production date XJS.
So my read on this is the late production date '95 XJS' are OB2 compliant since the '96 XJS started production in I think around May or June of 1995. So if you have a lower priced scanner and it does not communicate with your '95 it may be for this reason and you will want to hook up a more expensive scanner and hopefully it will be able to communicate with your car and allow you to cancel the CEL.
  #42
Old 05-04-2019 | 04:54 PM
Spikepaga's Avatar
Just FYI, i have a early 95 with a 94 production date too, and I have a Bosch reader I got at Autozone that works really well.
zachster
09-20-2011 11:46 AM
tcbjaguarxjr
11-15-2009 02:01 PM
tcbjaguarxjr
07-29-2009 09:24 PM
Margo
05-14-2009 11:38 AM
ak_jag
05-23-2008 03:06 AM
Quick Reply: No start condition
