No turnsignals, but hazards work
I have the 1993 XJS running pretty well, even took it around the neighborhood the other day. One issue Ive found is that my turnsignals dont work, however my hazards work fine. I checked the fuse and it looks fine. Lights switch and everything else on the stalk work fine. Any ideas?
You'll have to locate the turn signal relay . Can't see it being the stalk if both side don't work.
Yes I was kinda just saying that everything else on the multifunction switch is working, and yes I understand that none of the other things are connected to the turn signals. I didn't know if the hazard and turnsignal relays would be the same one or not. I just thought it kinda odd that I would have the one working but not the other
Check both power inputs to the hazard switch. One is from the switch ignition power (29) and the other (16) seems to work the hazards as it is battery power. 29 (go to the power distribution page) has a fuse. Did you check that? It could also be the hazard switch too, meaning even though it is working itself, it may not be passing the switched power through to the flasher unit witjh key/ign on. Try to bypass the multi function switch on the column. I can't see that switch being bad in both directions. Pull the hazard switch out and re-seat the plug and while you're at it, check for input power from both 16 and 29.
I just got them working! I cleaned out and lubed the hazard switch, no go. I checked the fuse and it had power to it. Pulled the fuse and noticed the blades had a little corrosion on them. Cleaned and dielectric greased the blades, and they worked. Smh. Sometimes its the simple things lol. I needed to do the switch anyway because it was sticking
sbreeden
05-27-2012 05:34 AM
Bacardi 151
12-07-2011 01:46 PM
vdpnyc
03-14-2011 08:41 PM
