No Windscreen Washers
My windscreen washers do not work. The wipers work. There is no blown fuse (#8). Of course the low washer light is always on and there is plenty of fluid in the reservoir. I took off the inner fender well to expose the washer bottle. I did not take it out but maybe I should. Taking the tire off to get to it is a pain but I'm sure I'll do it again. Is there a separate fuse for the washers or relay for the washers? I couldn't find anything in the manual about a washer relay. Can anyone out there give me any ideas?
http://www.jagrepair.com/images/Auto.../jvs1995en.pdf
Download that manual, then check out pages 30 & 31 as well as 50 & 51.
There apparently is something called a Wiper Logic Module that could be failing you?
Great, that's just what I need. A wiper logic module. Where the heck is that located? And what does it look like? I downloaded the schematic. Sure is a lot of stuff just to wash the windshield, not to mention the headlights. Heaters for the washer fluid!!!! Yikes!!!!
Looks like I've got a lot to do.
