Non starting 4.0 litre
After purchasing a 93 XJS 4.0 litre at the weekend I did 150 miles trouble free.
Gone out to start this morning and whilst the engine cranks she will not fire. I can smell fuel so don’t think it’s fuel related.
I’ve got a feeling an immobiliser may have cut in but don’t know if it can be overridden?
Any help gratefully appreciated please!
Hi
K55XJS
That description also sounds like the inertia switch to me
And while of course it could be that, the immobilizer is usually controlled by a button on the Key Fob
When you Crank the Engine. can you see the 'Tacho Needle' Flicker? as although its not a definitive Test, it could point to a failing CPS Crank Position Sensor
Also pull a Spark Plug and see if you get a Spark
K55XJS
Brewtech (09-21-2021)
None of our cars ever had a chipped key, so there wouldn't be anything else holding you up from starting the car....not by design anyways.
orangeblossom (09-21-2021)
Next thing I think would be to test for spark and usual suspects. Be sure about fuel at rail, crank with finger in a plug wire hole, that sort of thing.
