And now another problem pops up
In a recent post I mention the Ol' XJS is running great and about to be back out on the road, Well hit 2 snags, one not major, one is. Ran a vacuum on the A/C system, all was great, but when recharging the clutch would not come on, 1st thing I figure is to check fuse/relay, and ensure that the wiring/connections are tight. 2nd Major Problem to pop up, the right side CAT got cherry red. Guess I will have to check The CAT by tapping it to see if it ok, and even though I have all new HT leads, plugs, rotor and cap, check them for proper sprk. The injectors were sent out, cleaned and tested and fuel rail was cleaned. all fuel lines are new, as are the regulators. injector Harness was remade and moved out of Death Valley. So time ti go back over and break things down to see what is going on.
![Icon Viking](https://www.jaguarforums.com/forum/images/smilies/icon_viking.gif)
Oh the joy of owning an older Jag
![Icon Handball](https://www.jaguarforums.com/forum/images/smilies/icon_handball.gif)
Check the in line fuse under the RH console cheek.
Basically where your LHD passengers Left knee will be.
Remove the cheek, remove the footwell metal vent, and tucked up above and forward a tad is an inline fuse. It is attached in a plastic strap, to the system thermostat switch, and on the RHD cars mostly got at by "feel" than sight. Your LHD is probably a snap for access.
Cats, no idea, we no got down here.
daverb (07-31-2016)
