O2 sensors
My '90 with Marelli displays symptoms of dying O2 (Lambda sensors). Are these bog standard sensors? The wiring diagrams show three wires: Ground (Black), Pre-heating (Brown/Grey) and Signal +ve (Green). However, the three wire sensors available off the shelf have Black for the signal and two white for the pre-heating (+ and -). Are the Jag sensors special or the same as some other brand? (Presumably the Ford influence didn't show until the facelifted 6 litre.)
I don't know if the thread is similar either, metric/UNF etc?
Received 10,880 Likes
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Anybody know for certain?
EDIT: I found another wiring diagram which shows the config I have. The blue one is O2 signal, and the two white ones are the heater. Case closed
![Icon Sultan](https://www.jaguarforums.com/forum/images/smilies/icon_sultan.gif)
