odb codes
Here's a quick preface to my problem. I had a rattle under the car when I bought it so I ended up ordering a new down pipe with catalytic converter. I took the old pipe/cat off only to find there was a broken weld and the heat shield was crap. I had it re-welded and scrapped the heat shield and put the old down pipe/cat back on, installed the 4 O2 sensors and ever since I've had a p0138, p0420 and p0430 code. Any suggestions? Can someone explain which bank is which (where the pre-cat O2 sensors plug in on the drivers side of the engine vs. post cat O2 sensors which plug in the passenger front corner) and which sensor is 1 vs. 2? I bought two new walker O2 sensors which I understood when I ordered them that they could be used either before or after the catalytic converter but just don't know which old sensors to swap out.
Tyler
Tyler
Received 10,916 Likes
expedio2005 (04-15-2012)
philwarner
25
06-26-2021 05:43 AM
