ODBII Tools Giving Me Grief
Hi Team,
New to the forum here. As posted in the newbies section, I am taking care of my mother-in-laws 96 XJS convertible with the 4.0. I am having a heck of a time getting any ODBII scanners to work. I have tried my cheap Artilink 200 and my ODBII cable adapter hooked up to my laptop using FORSCan but they won't connect. I "think" this is the first year where ODBII was used or in the middle being used. I'm fairly certain that my cheap tool is just that, cheap and isn't compatible. Anyone know of a tried and true scanner that works with this year and model?
Thanks!
Mike
Thanks!
Mike
Mike,
The XJS is not fully OBDII-compliant, BUT from 1994 onwards it has a degree of compatibility. My 94-built car works with the cheapest £4 Bluetooth OBDII adapter. With the Torque Pro phone app I can reset engine codes and see quite a bit of data. If you want full control you really need a laptop running IDS /SDS. It all depends what you want to do.
Good luck
Paul
Good luck
Paul
