odometer fuse
Received 10,952 Likes
The speedometer fuse is probably #4 (10 amp) in the main fuse panel behind the LH knee panel.
To clarify, though, the *odometer* does not have its own fuse, and the speedometer fuse is shared by the other gauges. If the other gauges work the fuse is OK.
If the speedometer works but the odometer doesn't the problem is in the instrument itself
