Odometer on XJS not working, speedo kind of works...
Hey guys,
The odometer on my 1991 jag XJS v12 does not work, neither does the trip odo. And the speedometer works but is 15-20mph behind the speed I am actually going when driving. Very odd. Is this an easy fix? How expensive could this repair be? Any suggestions or comments at all? Anything is helpful
Thanks!, Scott
Thanks!, Scott
Scott,
I just replaced the speed transducer in my 87. The part cost around $100, and it's a pretty easy fix...unscrew the old one and screw in the new one and reattach the wiring connector.
If that is your problem I don't know. My speedo got slowly more erratic, showing correct speed...dropping to zero...showing correct speed, and slowing getting worse until it quit all together. Replacing the transducer fixed it.
My trip odo doesn't work correctly either. It "works" in the sense that it records the miles, but I can't reset it. I've not really put a great deal of effort into trying to figure it out as I have bigger fish to fry with the car.
I only posted because you said "anything" would be helpful :-). I would guess that maybe you have a "zeroing" problem with your speedo, but not sure how to fix that. Others will chime in.
Good luck!
John
1987 XJ-S V12
64,000 miles
Good luck!
John
1987 XJ-S V12
64,000 miles
JagV12 (11-03-2014)
FS[NorthEast]: 1991 xjs v12
DrScientist
12-09-2015 07:36 PM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
