OEM Camcover Gasket VS Aftermarket Gasket
Would like to mention that the OEM camcover gasket (NBC2525AA) fits way better than the aftermarkets. The spark plug well gaskets (NBC2579AA) seem to fit the same either way, but I would strongly recommend to stay away from aftermarket camcover gaskets...very strongly.
Don't forget to replace the thirteen isolator/seals (NBC2575CA), if you haven't changed them in awhile. I used aftermarket from Rock Auto since the OEM seems ludicrously priced.
And don't forget the TSB on the torque values...
prodigy215
08-27-2012 06:19 PM
