OEM fog lights and covers '92 XJS
jaguarjoe470 (07-29-2015)
jaguarjoe470,
Be careful because there is a difference between the lights used up to April 1993 and the ones used thereafter. They look the same from the front and almost the same from the back (to the uninitiated). But the rear brackets that are riveted on the case are "upside-down" on the post-93 because of the different hanging position on the big-bumper models. I also think the wiring plug is different but you could cut that off and rewire a connection. If you get the wrong ones, they'll mount at the wrong height. I'm not sure if they'll foul the bumper - perhaps not. All of this may not worry you, but as least you know what to look for.
Good luck, they go for big money! I've seen just the plastic overs for sale for £200!
Paul
Paul
KarimPA
09-03-2015 07:32 PM
