Oil light, idiot light for oil
1989 XJS:
The oil light on dash stays on after engine has started. Oil pressure GAUGE moves after starting, moves to about 25 lbs and then drops slowly which seems to indicate regular oil pressure.
So, I replaced the oil pressure idiot light sensor-and the light is still on!
What next?
What next?
1989 XJS:
What next?
What next?
As Baxtor said.
If the light is ON with the wire unplugged from the sensor, that wire is grounded in the loom somewhere.
The gauge sender is notoriously unreliable, so for show it is mainly.
Just to be sure, attach a master mechanical gauge to the hole where the idiot switch should be and take some real time readings.
Mine was 90psi cold at 1000rpm. 45psi,hot, at 1000rpm. The dash gauge was close for the cold side, but around 15psi for the hot side.
You, SIR, will go a long way in the world of the V12, trust me.
Doug calls it the "Fiddle Factor" and I like that a lot.
