Oil pressure gage: sensor or potential problem
Had my 88 XJS about 6 months now and getting used to all the typical quirks.
Just recently noticed the oil pressure gage is acting a bit off. Since I bought the car, the pressure has been in the 75-100 area all the time. I've noticed now that the pressure gage drops to the bottom when I put on the brakes and stop at intersections and such. Once I step on the pedal, it rises back to the 75 range again. I also see that it runs around 50-75 when in nuetral or parked.
I'm wondering if I need a new sensor. As I said, the pressure seems perfect when driving or parked, only when foot on the brakes does it seem to drop.
Any suggestions>
Any suggestions>
Received 10,876 Likes
I suspect a grounding problem. Remove the cluster, clean all circuit board contacts and connectors, add a redundant ground, report back :-)
I remember the gauges on my '88 did strange things whenever I turned the headlights on. The above repairs put everything right.
Not sure if you are talking V12 or six cylinder here.
75 to 100 seems quite high for a V12 (can't tell on mine as the gauge is stuck) but on the previous 12 bangers that I have had 50 to 70 was a good pressure.
On the 4 litre six pot that I have had I have put 3 new senders in 4 years in it.
After market stuff is *****, I am going to stick to OEM from now on.
Although the new relay for the auxiliary fan on the V12 lasted 5 weeks.
So what do I know?
So what do I know?
I'm pretty sure it's an electrical problem. It only is affected when I put on brakes. When it's in park, Or neutral it runs at about 5-10. Then rises to about 65-70 while driving.
When I first bought the car, the gage read 100 the minute I turned the key. Now I'm thinking it may actually be reading properly!!!
