Oil Pressure Guage
I recently (40 miles ago) had a major overhaul of my 1992 XJS 5.3 Convertible. All of the electroincs behind the dashboard were repalced....among many other things. When they fitted the electronic module for the oil pressure guage they had some issues which seemingly were resolved. Now, after driving only 40 miles the guage "pings" from right to left etc at a rapid speed when the vehile is in idle. However, once i apply throttle the guage immediatly resets to the normal steady reading of around 70psi.
Any suggestions as to what the problem is?
Received 10,920 Likes
Electronic module? Do you mean sending unit?
My off-the-cuff guess is that the sending unit is faulty or incorrect.
What so-called issues did they have with this?
Try to find out what sending unit they used. The original type was discontinued from Jaguar years ago and replaced with a fixed-reading type. However, the original type can be found via the aftermarket with a bit of searching.
If they used a generic replacement (not saying they did, mind you) it might give weired readings.
