Oil pressure sensor part number
I just tried replacing my leaky oil pressure sender with URO C46272 and it does not seem to fit. It threads in a few mm as if the pitch is incorrect. Somehow, the replacement water temperature sensor (DAC2583) I ordered is doing the exact same crap.
Wtf?
Anyway, the pressure sensor broke further when I removed it, and I am afraid it would leak too much to use temporarily now. I need to get a replacement ASAP, but I don't want to order another one that won't fit.
Does anyone know whether standard motor products PS293 would fit? It is my only other option on Amazon where I could take advantage of 2 day shipping. I'm sure a Jaguar parts retailer would be more likely to get it right the first time, but that would probably put me nearly a week out in shipping and I need to get to school.
EDIT: I'm getting even more confused and unsure of ordering parts because reputable sites like XKs, Terry's Jag, and Jagbits are listing these same part numbers.
Wtf?
SS
The OPS has a taper thread, as it goes in it tightens and jams slightly, by design, which makes it seal. Just do not force it. The WTS is, as far as I can remember not a taper thread but I could well be wrong. Rockauto have these parts, usually by more mainstream makers, and they do fit.
Greg
Greg
Try Genuine Jaguar Parts and Jaguar Accessories for classic Jaguars from Jaguar Classic Parts UK
Idk how I forgot this, but my dad just called and will be sending me the one off of my spare engine at his house.
I will be measuring the originals and replacements and posting that info in case someone needs it for future reference.
I think the issue may be something along the lines of a manufacturer (URO) thinking something is compatible across platforms and labeling part numbers as such.
Greg in France (11-12-2016)
Maybe SNG barratt will be a good bet? I'm just afraid of slow shipping times.
Received 10,920 Likes
Received 2,399 Likes
If in a time crunch, I've two ideas. Each a bodge/dodge!!
1. Take the sensor to the nearest full service hardware store.
Match the sensor threads to a simple plug. No leaks, make sure the sump is full. go to school. Then, to the proper fix.
2. Ruin the ruined original. Knock or grind off the "top". Leaver the threads and as much of the "grip" part as possible. Drill out the center. Install a bolt and nut. Lots of sealer. You have created a plug.
OK til the right sensor becomes available.
David Boger. Everyday XJ. Good used or NOS!!
Carl
Carl
So found the sizes (with difficulty).
New temp sensor is 14mm fine (1.5)
Old temp sensor is 5/8 fine
New oil pressure sender 14mm fine
Old pressure sender 13mm fine
Since 13mm is so close to 1/2 the hardware store didn't carry any 13mm (13mm=5.12"). Between Autozone, Advance Auto, and Ace hardware, no one had a thread pitch gauge >_>
But after finding the other thread sizes and knowing what didn't fit, I can safely assume the M13 1.25 listed on summit racing is the correct size. I haven't looked into it more yet, but it would appear these parts are for face-lift cars and are being listed as compatible with my 1988, because the correct m13 is listed on summit for a 1981-1991.
I did consider plugging it if I found the correct size at the hardware store, but they don't carry M13...
Carl
Carl
It sounds like you need the Oil pressure switch for the Gauge not the light. Check out PS288, Might find it at a Auto Zone in you area. I use Orielly's where I'm at and the Borg Warner number is BWD- S4100. These use the crush washers, not a tapered thread like the Light switch has.
Good luck
Paul
Greg in France (11-13-2016)
Does anyone know where I can find the correct sending unit for the gauge on a 92 V12? its a face-lift car with XJ40 style gauges. I'm getting a few different part numbers when i search but the one on the car is the smaller style with the wired in resistor. Needle is just sitting dead on the pin but the oil pressure light goes off on startup.
Kevin
Kevin
