Oil sump pan leak fix
Old 01-23-2023, 12:37 AM
Greg in France's Avatar
Received 9,334 Likes on 5,476 Posts
Another VERRY important point I forgot to make explicitly.
The bearbox surface that the gasket goes against MUST be 100% dry and oil free. Use brake cleaner aerosols spray or carburettor cleaner aerosol spray to clean it and dry it very carefully. It is a good idea to let the open gearbox drain for a couple of days before cleaning it, and have the sump assembly all ready to fit once it is cleaned and dried.
Gasgacinch on BOTH the gasket AND the gearbox.
The following 2 users liked this post by Greg in France:
LnrB (01-23-2023), orangeblossom (01-24-2023)
Old 01-23-2023, 03:17 AM
Philikat's Avatar
Hello Greg.
I know that it is necessary to clean perfectly the Pan and the gear box surface before Gasgancinch.
I will respect your procedure perfectly.
I have everything I need in my garage to do the perfect work, and I’m sick and tired of dismantling that Pan four times already............
I’m still going to wait for the temperature to increase a bit to get the job done.
And sure I will pass with big palisir in the spring to Digoin with the E type.
Regards.
Philikat.
Old 01-23-2023, 05:09 AM
Regards.
Philikat.
Great plan, I look forward to it!
Old 02-03-2023, 01:49 PM
Philikat's Avatar
Good evening Greg.
I get the pan gasket today.
I will do the job this week end, not inthe garage it is to cold, but in my house.....my wife will appreciate that a lot for sure.................................
Take a look on this photo.
it’s the right model from FELD PRO as you advised me.
Thanks.
Philikat.
Greg in France (02-04-2023)
Old 02-04-2023, 12:10 AM
Good luck.
Old 02-11-2023, 06:56 AM
Philikat's Avatar
Hello Greg.
I did the work yesterday enjoying a beautiful day of sunshine.
Resting all night, but I’ll wait till tomorrow to see the result.
My wife said nothing..........
I wait new screws to put it back in place.
Some photos....the same as yours finaly.
Kind regards.
Phil.
Old 02-11-2023, 08:06 AM
Looks great! Very sensible to let it set good and hard.
  #28
Old 03-11-2023, 12:46 AM
Philikat's Avatar
Hello Greg.
I took some time to answer you because the last assembly didn’t work, I still had oil leaks after 15 days despite all the care taken to the work.
I checked the pan with a comparator and it’s completely deformed by the tightening of the screws.
As I had 2 pans I decided to use one and strengthen the edges with 4 mm flat iron that I formed all around the case.
Once in place I welded the flat iron in the rim of the pan blocked onto a mechanic’s marble.
Photo 1 an 2
This work finished I had rectified the surface by a milling machine.
Yet i have only a little section with only 0.2 mm under the surface and everything is totally rigid.
I do the assembly this weekend without gasket by putting only LOCTITE SI 5980 Quick Gasket between the pan and the gearbox.
24 hours of drying and filling.
I cross my fingers, it will be 4 times that I empty the gear box and disassemble the pan ...........
It is nothing to compare with the original pan.
Regards
Greg in France (03-11-2023)
Old 03-11-2023, 02:23 AM
brinny's Avatar
Have you checked your breather pipe and crank vent valve are all clear
  #30
Old 03-11-2023, 02:44 AM
Philikat's Avatar
Hi.
Thanks for your advice.
Yes I did all possible control around the gear box, and of course the breather to be sure to get no pressure into the gear box.
I made also a drawing with all dimensions to understand how the oil level works when the gear box is cold, hot and turned off.
I'm a perfectionist and I real can't support any oil drops under my cars.
I need to admit than was only in two weeks few little drops on the floor .........but to much for me.
When I was looking back some photos, I took during this major overhaul, I remember than was no gasket on this pan!
Yet I go to install my montage.
Regards.
  #31
Old 03-11-2023, 02:54 AM
I think that is an excellent design and idea, with a very good chance of meeting your high standards. Keep us informed about progress.
Out of interest, and knowing that you tried my idea using The Right Stuff and glass etc, how much oil actually dripped out every day?
  #32
Old 03-11-2023, 06:07 AM
Philikat's Avatar
Hello Greg.
Your idea to use a glass is really good.I found that my leaks were reduced after using your method, but not completely!
Like I said.... 2 drops per day....I know it is almost nothing but.....I can't see that under my car......and also because it is uncertain how that will progress with the time.
Just 2 hours ago I dismantled the pan from the gear box, all washers under the screw heads, were tapered as they are tucked in the holes of the pan!
Now with my 4 mm flat iron, that will be impossible.
It was quite difficult to put the pan away, this Gasgacinch is a real fantastic Gasket (Glue), It stucks so hard.
After Lunch back to garage and implementation of the modified pan.
I cross my fingers.
Verdict tomorrow afternoon.
Regards
  #33
Old 03-11-2023, 09:04 AM
Rescue119's Avatar
I used the right stuff with no other gasket and it hasn't oil leaked from the pan since. Works great.
Pan bolts are only 10 ft/lbs
The following 2 users liked this post by Rescue119:
Greg in France (03-11-2023), LnrB (03-11-2023)
  #34
Old 03-12-2023, 02:26 PM
Philikat's Avatar
Good evening everybody.
No leaks finally, I'm so happy I can't believe......... I will wait tomorrow to check again under the car,.
The mechanical assembly I made, leaves little chance to chance and it should be definitely waterproof.
To be honest, I wanted to do this mechanical assembly as soon I discovered these leaks, but the amount of work I had imagined to realize these reinforcements discouraged me and I opted for other solutions to make this adaptation anyway!
Now I will use my car and enjoy every moments behind the wheel.
Thanks for your advice and your support.
Philippe.
Greg in France (03-12-2023)
  #35
Old 03-12-2023, 02:40 PM
Philippe
Many congratulations. I think that mod is absolutely the best. I look forward to seeing it!
NTL1991
XJ XJ12 ( X305 )
12-01-2016 08:02 AM
05S-Stype
06-25-2016 04:11 AM
Bill C
05-25-2016 08:04 PM
FloriVol
10-23-2011 01:36 PM
Michigan
General Tech Help
03-12-2008 08:12 PM
Quick Reply: Oil sump pan leak fix
