ok new wheel idea...scratched the last one
Old 05-23-2016, 07:32 PM
H&Kjaguar's Avatar
Default ok new wheel idea...scratched the last one
I was going to change out my 15 inch rims for a different set (Lattice) but after speaking to you guys and learning how freaking hard it is to get tires anymore in that size....I stumbled across these
They are (hope the picture shows up properly) 16 inch factory rims from a 95/96 XJS I think. Mine is an 89 couple v12. From what I can tell the bolt pattern and offset are the same...the only difference is that the factory 15's I have are 6.5 wide I think and these are 7 inches wide. I think they will still work on my 89 XJS however...
Any insight? Seems like, as you have been kind enough to tell me, there are MANY more tire choices in the 16" range than the 15"
Attached Thumbnails ok new wheel idea...scratched the last one-jag-wheel.jpg
XJ6Paul (05-26-2016)
Old 05-23-2016, 09:23 PM
Padre's Avatar
They should look great and fit well.
Don't worry about the 7" width.
For more information, the part number is MHF1663AA. Looks like they were available from 93-96.
Go for it.
Padre
Old 05-23-2016, 09:39 PM
H&Kjaguar's Avatar
YES!!
Those are the ones
Thank you
Seems to give me a plethora of tire choices compared to the 15 inch rims!!!!
So do I use same tire size and just go up from 235/60 15 ....to......235/60 16 ????
Old 05-23-2016, 10:26 PM
Padre's Avatar
No, those would be 1" taller. Your speedometer would read 3.69% slower.
Look for tires that are 26.1" in diameter. 225/60-16 or 235/55-16 would fit.
Check here: Tire Size Calculator - Tire & Wheel Plus Sizing
Padre
Old 05-23-2016, 11:24 PM
H&Kjaguar's Avatar
Ton of options in the 225/60 16's
Nice!
Thank you
Old 05-24-2016, 04:54 AM
orangeblossom's Avatar
Received 3,771 Likes on 2,611 Posts
Those Wheels shown in your Photo, were one of the options available on the 95/96 Celebration Model.
And I have even considered fitting them on my own 89 V12 but as I picked up a new Set of Lattice, at a bargain price and can still get hold of 15 inch tyres, I want to keep her the way She is, at least for the time being.
Old 05-24-2016, 05:51 AM
ptjs1's Avatar
Received 3,033 Likes on 2,015 Posts
H&Kjaguar,
As mentioned, those are the standard XJS wheels that became normal fitment from April 95 until the end of production. It fits straight on to your 89 car.
It was fitted with either the 225/60 16 or the 225/55 16 tyre. I would strongly suggest that you stick to one of these standard tyre sizes. 225/60 (with the correct weight rating) is a little more difficult to find in the UK compared to the 225/55. The 225/55 is a very slightly stiffer tyre, which I prefer anyway. I moved from 225/60 to 225/55 some years ago on my car.
Good luck
Paul
Old 05-24-2016, 07:38 AM
Eurobahn Jaguar's Avatar
Sponsor
Think those would look great! Nice choice.
Old 05-24-2016, 08:00 AM
H&Kjaguar's Avatar
Thanks ! I am picking her up from SC and taking her home finally to Florida after getting her refreshed and running like a top
Really looking forward to it...its my first one so I know I am in for a treat
What tire weight is recommended?
I will keep the 5 star wheels so I can keep it as original as possible as I believe those are the ones that came on it from factory...so I can put them aside and if need swap them out...just seems in the 15 inch range you either get Perelli P600 for like 300+ per tire... or you buy something that's about 72 bucks a tire when you can find it in size Frustrating it seems
Old 05-24-2016, 11:12 AM
ptjs1's Avatar
H&Kjaguar,
If you're going to run 225/55 16 then I would look for a 98 load rating. 95 might be ok, but I run 98. Some owners even go for 101 rating. Don't go for cheaper tyres with 92 or 93 ratings. I don't know if you have insurance companies over there who consider these things, but in the UK, one of the first things they'll look at if you're unlucky enough to have an accident, is the tread condition, speed rating and load rating of the tyres. If you're running tyres with ratings not consistent with manufacturers defined standard, then you'll be in trouble.
Paul
Old 05-24-2016, 10:49 PM
BC XJS's Avatar
I'm going to replace my rims with these. 18" with a different off set but I believe that I can find better selection of tires.
Attached Thumbnails ok new wheel idea...scratched the last one-38844629_614-1.jpg
Old 05-25-2016, 04:00 AM
John1949's Avatar
They look terrible and will not fit properly and if you send them to me in Australia I will dispose of them for you !!! I have just fitted a set of 17" with lower profile tyres , but not to low a profile and just roughly they were only around 10mm (3/8") taller than the standard wheels .
Old 05-25-2016, 01:55 PM
RonaldP's Avatar
18" wheels with the same circumference tire as the stock tire will leave you with a very short sidewall and may give you a harsh ride.
Old 05-26-2016, 04:00 AM
John1949's Avatar
My previous post was referring to H&k's 16" wheels and I think he will have no problems in maintaining close to original diameter . I agree with Ronaldp , I have had very low profile tyres on my Skyline the ride is harsh and after hitting a pothole lost the tyre and damaged the rim just not enough sidewall rubber, having said that I think my XjS looks better with my 17" wheels as before it looked like to much rubber and not enough wheel , like H&K I am keeping the original wheels just in case .
Old 05-26-2016, 05:42 AM
dcarr's Avatar
When I found that I couldn't get Z-rated tires in a 15" size, I looked around for 16" wheels for my 1986 XJS.
I finally decided on the later-model Jaguar Vanden Plas wheels. I think they look great. But fitting them required:
Installing longer wheel studs on the front;
Modifying the back of the front center caps so as to clear the grease caps;
Thin wheel spacers to provide just a little bit more clearance.
Old 05-26-2016, 09:21 AM
paydase's Avatar
Not bad, the VdP wheels.
Coming back to wheels diameter, after having considered putting 17" wheels, I will keep my 16", I believe they best fit our cars' philosophy and comfort (not John Walkinshaw racers...) and, I would even dare say, overall balance of design
Old 05-26-2016, 10:53 AM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
Paul:
That "Nanny" state syndrome. Can't stand it. Politico's
her seeking to advance it.
So far, not on the wheel and tire thing...
If I so chose, I could bolt on wooden wagon wheels with steel rims, no rubber at all!! But, if I got in an accident and they had something to do with it, it might impact a civil claim for damages.
So, my XJwuzza 6 wears T rated B. F. Goodrich 260 x 70 x 15's
on 7" XJS sourced lattice wheels. My car is probably capable of exceeding their speed rating. Will I drive in excess of 125 mph
for an extended period. No!!! But, I can dream....
Carl
Old 05-26-2016, 08:08 PM
BC XJS's Avatar
I was not asking for YOUR opinion or permission. At all. I prefer performance. But if they're good enough for the XJR there good enough for me.
Old 05-26-2016, 09:29 PM
baxtor's Avatar
Received 1,149 Likes on 744 Posts
Seriously, did you miss the tongue in cheek in john's post. Lighten up.
John1949 (05-26-2016)
Old 05-26-2016, 09:58 PM
John1949's Avatar
Thanks baxtor , I thought the comment " send to Australia " would have been obvious as humour H&k's wheels are stunning .If BCxjs had scrolled down further he would have read that I was referring to H&k and not to his wheels , which I might add have a similar spoke look to the wheels I have just fitted to my car , it was just unfortunate that his post and picture appeared before my post . If Bcxjs reads this , for the record , I would never be so rude to anybody .
Quick Reply: ok new wheel idea...scratched the last one
