The old 88' starts and runs a tad rough! vid inside
Old 05-20-2017, 04:06 AM
Greg in France's Avatar
Received 9,254 Likes on 5,435 Posts
Originally Posted by 944xjs
also, do I have to take off the air pump to get the dang wiring harness out from under it?! Ha jeez the right side doesn't want to come out from under it. Can't wait to clean it all up, a Jag V12 is a mouse castle
About 10 minutes with a hacksaw gets the whole mess out, nothing to it. Leave the pump in place and also the pipe that runs from the pump to the rear of the V. Then everything is much much easier
  #42
Old 05-20-2017, 06:33 AM
Received 10,480 Likes on 6,920 Posts
Been away collecting an X300R, tough life.
ANYWAY, looking at the snap of those injectors in post 39, those barbs where the fuel hose push on are NO good for the ferrule system, they will leak, and like Doug "coughed up" about plate orientation, I know by default.
Whoever removed those old fuel hoses has scored them badly, and the "sharpness" of the barb is gone, and will NOT grip the new hose.
You will need to sit down, carefully smooth the edges of those barbs, and then take a nail file, and even more carefully file those vertical scratches out of the spigot, and I do mean carefully. Then you will need EFI clamps with the new hoses, and NO ferrules.
If those vertical scratches are left as is, the fuel WILL flow up them and set fire to your new toy, fact. It will matter NOT, how good you clamp them, those scratches are a fast track for hi pressure fuel.
If you dont understand what I mean, ask, and I will go into great depth for you.
That odd injector is very suspect.
Greg in France (05-20-2017)
  #43
Old 05-20-2017, 10:29 AM
944xjs's Avatar
I see what you mean. Yeah I know that the fuel hose on that injector came off real easy. I was actually kind of surprised. I took that one off right away to save the hose for measuring the new efi hose im going to get. Too bad Jaguar waited so long to integrate the fuelrail. Could've saved a lot of headaches and fires. Well I guess I'll just stick with the efi clamps and inspect them every so often.
  #44
Old 05-20-2017, 10:33 AM
944xjs's Avatar
thats too easy 😀. I want to inspect and study the whole harness to see if I have the ability to redo it or just the ability to replace the connectors. Ha
  #45
Old 05-20-2017, 12:42 PM
I as referring to the air injection pipes. NOT the loom!
Grant Francis (05-21-2017)
  #46
Old 05-20-2017, 07:13 PM
944xjs's Avatar
oh haha..
  #47
Old 05-21-2017, 04:56 AM
I need a DRINK, damn.
  #48
Old 05-21-2017, 09:48 AM
944xjs's Avatar
Ha! You'll need one once I post a pic of the V when everything's removed. I'm surprised it didn't light on fire from the mouse crap alone!
  #49
Old 05-22-2017, 05:32 PM
944xjs's Avatar
Got everything out I need to replace(except the distributor cap). Cracked distributor should be fine... ha
Got all the nuts and mouse crap out and simply greened it as best I could! Could not believe the decomposed everything and dirt buildup.
  #50
Old 05-23-2017, 02:32 AM
Good for you getting it all out and decently clean. Now new plugs, cap, HT leads, injectors refurbed, and make sure the dizzy rotor snaps back when turned anticlockwise. If not carefully lubricate with fully syn oil at the base of the mechanism below the star wheel.
The wiring to and from the amplifier looks pretty rough too. It would be a good plan to make quite sure all those bodged up loom joins are good. Good luck with it all
  #51
Old 05-23-2017, 04:45 AM
Well done.
Lots of work there, but very doable.
  #52
Old 05-23-2017, 10:19 AM
944xjs's Avatar
Yep, I've already got new efi hose to redo the rail. Going to get some new plugs and injector plugs soon. Etc. now that it's all out I can take my time fixing it. Yeah I noticed a lot of the wiring to the amplifier looks rough as well. I'm going to check it all and wrap it if it's ok
Well done.
Yeah it's definitely more intense because of the amount of stuff. It's just double or triple the amount of everything I'm used to in one engine. I did the plugs, wires, cap and rotor on my Porsche in about and hour.. this has been a multi day adventure a couple hours at a time. Ha
  #53
Old 05-28-2017, 11:00 PM
944xjs's Avatar
Alright, so I finally got around to cleaning the injector and am I ever glad I did! I found one of the injectors is dead, which is why I'm sure it was running a tad rough.
question, I love utilizing my local junkyard for parts. Are there any injectors that are used in other cars from the era or even now that I could pull out of something and keep my project on the cheap? I thought I read once some Mercedes used them?
  #54
Old 05-28-2017, 11:14 PM
Doug's Avatar
Received 10,872 Likes on 7,151 Posts
I can't remember if there's a Bosch number on the injectors. If there is you might do some Googling and see what comes up. Injectors are pretty precisely calibrated to the specific engine, as far as I know, so I sorta doubt that any other car used the same injectors....but can't hurt to see what's out there. I could be wrong !
  #55
Old 05-29-2017, 12:16 AM
944xjs's Avatar
yeah I'll have to look... most of the injectors look beat to crap I'm not sure I can read the number. There is already one wildcard injector in the set that doesn't match.
  #56
Old 05-29-2017, 04:00 AM
My listing shows the Bosch # for the HE Injector as:
0 280 150 163
It is for the P Digital system up to 2/90 build date.
No cross reference to any other engine that I can find.
  #57
Old 05-29-2017, 11:47 AM
944xjs's Avatar
0 280 150 163
yeah I was searching... the ones in mine are 0280150161... still couldn't find anything but a few on eBay.
Grant Francis (05-30-2017)
  #58
Old 05-30-2017, 04:37 PM
JigJag's Avatar
My listing shows the Bosch # for the HE Injector as:0 280 150 163
Here are the pertinent Bosch specifications for #161-164. 161&162 are discontinued, but you'll find they all are identical in spec. other than hose length.
Code:
Injector type     OE NR.    Type    "Info production stop(status 01.2008)"    offer drawing    Resistance (Ohm)    Test medium    Operating pressure (kPa)    Operating pressure (PSI)    Q-stat (at operating pressure) (g/min)    Q-stat with 300 kPa (g/min)    Q-stat with 300 kPa (ml/min)    q-dyn with 300 kPa, ti 2,5 ms (g/1000 Imp.)    Spray type    "Spray angle alfa-50 (for 2 beam)"    "Spray angle alfa-80 (for cone-characteristic)"    axial deviation angle (spray bent angle)    Spray orientation angle    Spray distribution (area, spray amount)    allowed fuels    Version, type    Electrical connector    locating lug (anti rotation device)    hydr. connection to manifold    hydr. connection to fuel rail     "Distance between O-rings(O-Ring to O-Ring)"    Total length
0280150161    0 280 150 161    EV 1    production stop, ask!    A 280 400 177    2.4    Ch20v3    300    43.5114    143.4    143.4    205    4.19    A    ¤    19°    ¤    ¤    8°-30°¤>40%    ¤    1.1    Jetronic    no    special grommet    hose straight    ¤    115
0280150162    0 280 150 162    EV 1    production stop, ask!    A 280 400 177    2.4    Ch20v3    300    43.5114    143.4    143.4    205    4.19    A    ¤    19°    ¤    ¤    8°-30°¤>40%    ¤    1.1    Jetronic    no    special grommet    hose straight    ¤    160
0280150163    0 280 150 163    EV 1                             A 280 400 177    2.4    Ch20v3    300    43.5114    143.4    143.4    205    4.19    A    ¤    19°    ¤    ¤    8°-30°¤>40%    ¤    1.1    Jetronic    no    special grommet    hose straight    ¤    160
0280150164    0 280 150 164    EV 1                             A 280 400 177    2.4    Ch20v3    300    43.5114    143.4    143.4    205    4.19    A    ¤    19°    ¤    ¤    8°-30°¤>40%    ¤    1.1    Jetronic    no    special grommet    hose straight    ¤    115
I've purchased several manufactured by Intermotor and been pleased with their quality / performance. FJ633 is the Standard Motor Products (Intermotor) part number. Best price I find is at autopartskart.com. The GBR parts on that page are cheaper, but remanufactured. I have no idea their quality. Summit racing carries the Intermotor part as well.
  #59
Old 05-30-2017, 09:12 PM
944xjs's Avatar
Code:
the reman for $25 is nice... I'm guessing shipping to the USA will eat the good price though. I put a bid on a used eBay piece...
  #60
Old 05-30-2017, 09:40 PM
Jagsandmgs's Avatar
Rockauto.com has injectors for $27 each, with choice of long or short hose and ferrrule already installed.
