One way valve
Received 10,979 Likes
Absolutely essential
Absolutely not essential.
You get to choose
Search the archives using "EAC4126" and/or "EAC4168"
The need for this valve, and correct installation, and actual intended function, have been confounding V12 owners (well, some of us) for a long time. I removed mine and never looked back. Good idea? Bad Idea? Hell, I dunno !
Here's one conversation:
https://www.jaguarforums.com/forum/x...-0-v12-149397/
You get to choose
rgp (10-30-2020)
Rex
The Great Palm discusses it. I have, pre my coolant system simplification, tried:
My advice is forget about it and remove it.
- with the valve in place preventing fluid going from the spout to the banjo
- with the valve in place preventing fluid going from the banjo to the spout
- no valve.
rgp (10-30-2020)
Thanks all, I think I will depose of it. A couple of years after I bought the car I removed the small hose and the valve body was in place but the jiggle pin was missing. Never did find it. But I fitted a new one so water could flow to the banjo. Now I'm changing the small hose and I had fitted the new valve into the hose as I had fitted a later crossover pipe and the valve wouldn't fit in the filler neck.
Greg in France (10-31-2020)
