orphan vacuum hose
orphan vacuum hose
I found a vacuum hose not attached and can't find a place for it. Please see pics below. It is under the right rear intake and attached to the blue item in the pic. This blue (whatever) has one vac hose to the back of the manifold and this is a second hose that goes somewhere?
Thanks...Jimmy
Thanks...Jimmy
Received 2,399 Likes
On the right side of the engine, under the intake and along side the block there are many hoses. Most of them connect to valves and "T's" related to the air pump, idle speed, cruise control and air conditioning.
I will try to find the hose drawings and post them here.
Remind me...what year is the engine you are working on?
Mark
Mark
There are two vacuum lines on top of the intake manifold, one connects to the metal line that bridges over to the manifold on the other side. The other one loops underneath and connects to the brown plastic dump valve. I think that's the one you're holding.
Let me know if you need more pics. Also, if you google jaguar Xjs vacuum routing diagram or similar, you should find a website that shows all the variants. I know I've posted that link here on these forums as well
OK...found where the vac hose goes. Good news, It goes to the air switch valve. Bad news, the air switch valve is located between the engine and the firewall about 10 inches below the heater control valve. I could almost touch it with a very long screwdriver.
Does anyone have a good description of the purpose of the Air Switching Valve? I may have to leave it disconnected until the next time I pull the engine.
Thanks...Jimmy
Thanks...Jimmy
Thanks...Jimmy
Thanks...Jimmy
Can't remember which is which, one does deal with hot starting by controlling fuel pressure (increase fuel pressure if fuel temp switch is indicated high fuel rail temp. The other (think situated at rear of engine) controls air injection into the exhaust manifold for a short duration (45 secs ?) After engine start up to speed up catalyst getting up to operating temperature quickly.
My 1993 6.0 l UK model doesn't have air pump fitted so only has one vacuum switch I believe
Seann1212
10-28-2015 09:13 AM
