Outboard Disk conversion - Yes or No????
Ok, I have to decide if I go ahead and convert to outboard disks or not. I have everything necessary except the handbrake levers.
Fors as I see it
- Vented rotors with better cooling.
- Removes any issue with overheating Diff output seals.
Against
- Increased un-sprung weight approx 10kg, albeit with a lower frequency of oscillation.
- Need to source handbrake levers or fabricate something.
- Single piston slide calipers vs twin piston.
I guess what I am looking for is a discussion and input especially if you have experience with both IB and OB on the XJS.
Fors as I see it
Against
Outer fulcrum shaft in XJ40 is small diameter so XJS LCA's need to be bushed, and the handbrake is different, other than that they will bolt up no problem.
Samheath100
09-20-2015 08:21 AM
