outside mirrors
I learned another something new. The outside remote mirrors in '88+ models are slightly different than the '87 and below models. The former have a second black and white wire connector (two prong) on both the drivers and passengers side. Maybe it is some kind of ground?
The latter does not have the second two prong connector. The drivers side has a single black and white wire that is taped back onto the wiring harness but not connected to anything. The passenger side does not have this wire.
Received 10,920 Likes
Greg in France (04-23-2017)
Correct. Just disconnect the heater wires at the plug inside the door. Also, if you have the tiny little white mirror electrical connectors, clean they very carefully, and emery paper the prongs too. 90% of the time a non-working mirror is poor conductivity in one of those connectors. Also, using a small cable tie to hold the connector together is a good plan.
Greg
Greg
