Overdue oil change
Poor mans engine flush, DAMN, I still use it, just did the "big block" 2.1V6 X Type, and that oil was SAD.
1000kms later, with new oil and filter, still as clean as it went in on the dipstick.
ALL my Jags get that ATF dose from time to time, and always have from way back. Works a treat.
Last edited by Grant Francis; 12-17-2018 at 01:09 AM. Reason: spelling still sucks
The following 4 users liked this post by Grant Francis:
Heard the same thing about ATF. The Seafoam would loosen stuck lifters on overhead valve motors but not sure what it would loosen on overhead cam motors, except maybe just to clean everything.
Received 10,920 Likes
Yup! I often keep a pail of used ATF for cleaning really cruddy parts.....where the dirt and grease are really caked-on. Drop the part in, come back in a couple days, the caked-on crusty crud just slides right off !
The following 2 users liked this post by Doug:
Grant Francis (12-17-2018),
Greg in France (12-16-2018)
The following 3 users liked this post by Grant Francis:
ANY ATF WILL DO.
I put 1/2ltr in the X after I changed the oil and filter, brain fade, age related, and about 1500kms into the new oil that was discoloured already on the stick.
I drove it about 1000kms more, and the slop that came out was the worst I have seen, BLACK, slimy, stinky. So much for stamped Dealer Service records???
It will get another 1/2ltr later tonight when it cools down out there, 40c at the moment, beer time. Drain it again in about 1000kms.
Chasing a strange intermittent "rattling" noise tha I am convinced is a lazy VVT chamber, and based on the slime I have drained from this engine, those very tiny oil passages are surely gooed up.
Last edited by Grant Francis; 12-26-2018 at 02:23 AM. Reason: spelling still sucks
Greg in France (12-26-2018),
v1rok (12-26-2018)
Never had that issue in the way too many years I have used ATF.
Look at the specs for ATF, and among all the letters and numbers it is basically a "SAE10W" oil, with colour dye, and whatever it needs to make it what it is.
Prior to that, and a very long time ago, a Bake Bean tin of Kerosene was the flush of choice. NO snake oil companies around back then and even fewer Auto trans cars.
Engine running pour it in, leave it run 10 minutes (about 1 beer) and then shut it down and drain it, SIMPLE.
Greg in France (12-28-2018)
orangeblossom
02-28-2016 04:35 PM
