Panel light
This is an intentional feature of the car. The bulb out warning light should go out after about 15 or 20 seconds. It in effect tests the system when the lights are switched on.
If the warning light never goes out, then either there is a failed bulb, or the bulb failure units are malfunctioning.
jkann1 (04-26-2017)
Thanks... I found out the bulb on the driver side door is not on when the door is open the rest are.. would that cause it also the bulb on the driver side dash doesn't work either with door open .. but does when the lights are turn on by the interior switch... Thanks for your time
The fitting just prises out (carefully!) and the bulb inside is a 5watt festoon.
Greg
jkann1 (04-27-2017)
