Part bcc5579
Mac Allan (12-23-2020)
If by any chance you have a photo of them properly installed as a reference for me, I'd much appreciate it if you could post it. I want to make sure I install them with the correct orientation.
Thanks!
I have just fitted 2 of these from Aston Workshop Parts here in the UK. Fitted perfectly. Part no for the LH 83-123811-BA. RH is 83-123810-BA. £4.36 +VAT each.
https://www.astonparts.com/
Rob.
Rob.
Mac Allan,
I wanted to go and roll the wheels forward on the XJSs this morning as they've been sitting for a few months, so I got a few pics of the roof locating pin cups.
You should be able to see the orientation of the offset on the rubber cups. The one on the right hand side of the car shows the positioning the best.
Let me know if you need any more pics.
Paul
Paul
Mac Allan (12-26-2020)
#28
Mac Allan,
Paul
Paul
#30
#32
Knowing how a little about AM operated re. the Jaguar-derived parts for the DB7, I would guess they came from the same OEM supplier of the Jaguar part. It wouldn't make sense for AM to get these parts produced elsewhere.
I found that the trick was to carefully push down the bottom seat of the insert to pull the whole thing in without distorting the top part. Just be careful not to split it as you push it in. As Mac says, try and use something round that fits the profile of the bottom of the insert.
Good luck
Paul
#33
#34
THANK YOU!!!
Just wanted to say thanks to all, for ALL of the information on this thread. This is an amazing forum. I have been looking for these grommets for 2 weeks solid. I am hoping the wind noise is cut down when installed. I saw mine coming apart and they literally crumbled when I touched them. Once they were out the wind noise went up about 10x. We will see...
Andreas Schmieg
02-11-2018 12:14 PM
